Payback Credit
fisherman31
Why am I not getting the Payback credit? I bought the phone, ported my number. Did what I was supposed to do. ???
5 REPLIES 5
FYI, this is a peer to peer or customer based forum. You need to contact customer service and ask them about your issue.
Link???????? You're not helping.
fisherman31
No Visible. This was not the answer I was looking for. About to switch to another carrier....
There is no link, go to their website there is a blue box in the bottom righthand corner click on it, that will open chat. If it isn't on the main page click the help tab you will find it there.
Also, thanks for letting us know you are switching to another carrier, appreciate the departure notice.
