Payment method
2023commander
Can I pay a Visible bill with a Verizon prepaid phone card?
Are Visible prepaid cards available?
RyanBlakeIT
Hi @2023commander - Unfortunately Visible does not offer a prepaid card nor do Verizon prepaid cards work.  However, you could purchase one of those refillable Visa or Mastercard cards and use that as an alternative.
beav
Paypal is also an option.
