Phone Restocking (availability)
Jim-wy
I'm considering switching to Visibile and the phone I want is not available (iPhone 13 mini 256 GB).   Any idea how often they restock?  If it is infrequent I can consider a different phone option.
Moxie
Good question; unfortunately I don't have a good answer for you.  Seems like a lot of supply chain issues across all industries right now. Maybe someone else in the community can get help..
Best!
bfloyd1989
The price that Visible offers for the Iphone 13 mini is comfortable to what is offered either at apple or bestbuy.
I would just open a line with Affirm and just pick it up or buy it from there. Just ensure that you pickup an Iphone 13 mini that is unlocked.
Stock availability is internal to Visible team, so we cannot answer.
However i do suggest to try changing colors of the device if you are not peculiar about the color.
This is an anecdotal evidence, i changed colors and my transaction went through. As I wasn't peculiar about the color.
P.S: Please mark this answer as solution, if it helped you.
