Phone sevice
Derickc93
Looking to switch to this cell phone provider, need help with a carrier lock. They said all I would need to do is ask for a port out. Any help would be appreciated.
If your phone has a carrier lock on it by your phone service provider you would need to contact them to get the phone unlocked before you can port to Visible.
If you need instructions on porting to Visible check out this link.
https://www.visible.com/help/how-do-i-transfer-port-my-number-to-visible
