06-16-2025 12:51 PM
I am needing to know if I am able to still keep my phone number once I purchase a phone from you?
06-16-2025 01:57 PM
Yes, if you are a current customer you only need to transfer the SIM card or eSIM to the new phone.
If you are a new customer you will need to port your number into Visible. Make sure to keep your current carrier activate until the port is finished. Once the port is completed this will cancel your old carrier.
You can find information for transferring eSIM to new phone or porting in instruction at www.visible.com under the help tab.
