09-27-2024 04:20 PM
I wanted to ask if I buy a Verizon phone at Walmart just like The ones you have and I buy them attached to Verizon? Is it going to work most likley
09-27-2024 05:35 PM
If you buy any phone it needs to be unlocked in order to work on Visible. The other thing is it needs to pass the IMEI checker in order to be an approved device on the Visible network and have the ability to get a SIM for the phone. Hope this helps.
