11-25-2022 10:55 AM
Regarding
https://www.visible.com/help/port-in-promotions
Metro by T-Mobile is missing.
Or is it excluded.
Thank You
11-25-2022 01:11 PM
Metro by T-Mobile is 'considered' MetroPCS, but does not actually populate that in the port in screen.
Support said it counts for rebate card.
We will see
Visible, you should fix the info on port in promos. MetroPCS no longer exists and you do not recognize Metro by t-mobile .
11-26-2022 10:23 PM
I referred someone who was with Metro and they had no problem porting in.
11-28-2022 05:00 AM
Sure, but the question was about the rebate. Did they get a rebate.
