Port-in from Tello
Caplimbo
I have my line from Tello. Is it eligible for port-in promotions?
randymanmsu
Nope, check the fine print under the promotion. There is an eligble carrier clause. https://www.visible.com/help/port-in-promotions
But let me tell you a secret and don't tell anyone๐Ÿ˜€  Visible has no way of knowing if you ported your number from T-Mobile or you ported your number from Tello, if you put in that your number comes from T-Mobile you gonna get the promotion. I take no responsibility on this act I'm just telling you the fact
randymanmsu
<duplicate reply>
