07-04-2022 09:05 AM
Hi,
I have an AT& T number now. I was referred by a friend to join VSble. So I need to port my number from AT&T to VSBle. Will I get a new SIM card? Should I call AT&T for any info and let them know that I will be stopping the service.
So As soon as I am on VSble, will be priced at $40, but once I join the Party will my pricing automatically drop to $25.
PLease advise, So I can start to move to VSBle
07-04-2022 03:33 PM
If you have all your AT&T info (account number, phone number and pin) You have all you need.
.. Visible will take care of porting your number and notifying AT&T that you are leaving. If you have a compatible phone you might be able to switch faster with E-sim or just wait a day and Visible with FedEx you a traditional sim card. Once you activate your sim, join a party before your next bill cycle and you can lock in the $25 rate.
If you need more.....
Check out this page: https://www.visible.com/get/?3LJ6QRJ, it has all the info you need to know about joining Visible. When you use my friend code, 3LJ6QRJ, you’ll get your first month of service for $20-off!
Best!!!
07-05-2022 11:31 AM
The PIN you need to port out to Visible is not the PIN you sign onto your ATT account with. It is a special port out PIN. Sign on to your ATT account and search "port out pin". Once you port out it will auto cancel your ATT account. Do not cancel ATT account first.
