Promo to switch to Visible+ - Visible Community
jo9x92n0
Got an email that says
"Try Visble+ for 3 months at no additional cost with code PLUSCE38. Itโ€™s everything you love about the Visible plan, plus some extras."
I signed up using the $5 off 24 month promo. Would I lose my original discount if I switched?
VisibleRocks
My best advice is to contact customer service through the app and get the answer from them.
rjniles
I believe that 3 month deal is a promo for new customers, if you are an existing customer it does not apply.
event-driven marketing must be off; they sent it to me right after i signed up ๐Ÿค”
