β12-12-2021 11:14 AM
Hello World π
I just purchased Visible service and trying to activate it on my new Pixel phone π
unfortunately I can't install app on my phone, what are my other options?
i understand physical sim is one of them, but i can also add "provider" through settings menu (or scan qr code), but where do I get that qr code?)
thanks in advance!
β12-12-2021 05:27 PM - edited β12-12-2021 05:27 PM
No esim on android/pixel phones.
Only option is to order a physical sim by byod. You do need the visible app to activate. You can easily download that from the play store.
β12-13-2021 09:30 AM
that's not true: there are MANY Android' phone that ARE support eSIM.
β12-13-2021 11:37 AM - edited β12-13-2021 11:38 AM
No I am saying no esim on VISIBLE for android/pixel. Of course many support it but visible is iphone only for esim.
β08-27-2022 09:45 AM
If this was true at the time it is no longer:
https://www.visible.com/help/Which-phones-are-compatible-with-eSIM
The response was unhelpful, the OP was asking for the QR code (which I don't think exists, because I'm looking for it too).
β12-13-2021 03:28 AM
Why can't you install the app on your phone?
Visible has three ways to contact support: chat, Twitter, and Facebook.
I have had the best luck with Twitter:
https://www.visible.com/help/connect/
If I helped you, please hit the thumbs up/kudos button above.
3 weeks ago
Help in app does not find QR code. Where is my QR code for my account?
