09-16-2022 06:51 AM
Hi,
My device had to be reset and lost all network settings. I had recently been on Verizon and added Visible as a data plan. After the reset, my phone is defaulting to the inactive Verizon cell plan. When I try to add Visible as a plan it prompts for a QR code or manually enter a SM-DP+ Address with Activation Code (optional confirmation code). I can't find anywhere on the website to generate an activation code and the App isn't providing any help either. I currently can't access my Apple ID for that line since I can't two factor.
Phone is a 2nd gen iPhone SE. Any help is appreciated, I've been waiting to be connected to a live agent for 15+ mins...
09-20-2022 09:39 PM
did you figure this out?
09-21-2022 12:01 AM
You have to contact chat and tell them you were reinstall the eSIM they will send you a eSIM in the app
11-28-2022 01:57 PM
Any one know where can I find QR code for activation new phone?
