Referral Code not working - Visible Community
fastfollow
I have tried 15-day Visible trial and trying to sign-up using a referral code from family but NO referral codes work and so far Visible Agents have been clueless and not able to help.
The error I get entering the referral code is:
Code <code> is not valid or has expired.
Anyone know figure out how to use referral codes?
RyanBlakeIT
Hi @fastfollow - Someone from Visible should be reaching out to you shortly.  Please keep us posted on how things progress.
