02-12-2024 09:10 AM
Hi everyone. I have an Samsung Galaxy22 ultra getting 1 bar since the new rollout of Sim cards last year. I contacted visible tech-support chat, the rep sounded confident & took me from 1-2 bars to no service for 3 weeks.
I’m still having issues connecting to the visible network, sometimes, it’s a decent signal strength and boom, it shows no service.
I’ve done the airplane mode & power cycle. I’ve just now gotten my phone number associated with this SIM card and I’m scared to death of losing it because I couldn’t access my voicemail
Every time I log into visible chats , the first thing the reps wants to do is create a new eSIM and have me delete everything off my phone again. I’ve been escalated to a higher tech-support, but the emails are slow. I’ve actually found better instruction and directions on this forum than their tech-support. Lol I appreciate you guys helping me out on getting this fixed. I’m supposed to be getting the S 24 ultra whenever it comes but right now, I’m kind of nervous to put another ESIM on anything
02-12-2024 10:06 AM
You're using a physical SIM card currently? It should be safe to switch to an eSIM and you shouldn't lose any data or need to reset your phone to do that. Your phone number should stay the same and will be moved to the eSIM. There should be an option to switch to eSIM in the Visible app. If your existing physical SIM card is faulty, switching to eSIM might help.
02-12-2024 11:30 AM
If you don't want to switch to eSIM you can have them send another SIM card if you or they think that is the issue but you may lose service until the new card arrives. I am not a tech savvy person and have only had these smart phones for 2 1/2 years but from what I have read I would think switching from the old system we were on to the new system whether using eSIM or a SIM card would not affect the signal to your phone. It didn't for me when I upgraded but then I am far from the towers and was only getting 1 to 2 bars then and still am after the upgrade. It is the same signal from the tower to your phone, the only thing that changed is how the signal is processed, before your service was run through cloud based servers and now it runs through Verizon core system. I would not think that would affect signal but it certainly could affect your data speeds and possibly call clarity, for me those things improved but others have had it go the other way.
The only other thing that I could even think of is that maybe something happened to your phones antenna, you will find out when your new phone arrives if you have the same signal strength. It is possible that maybe a tower in your area went down for repair but I would think that would be fixed by now unless it got taken out completely at the time you upgraded.
02-18-2024 07:27 AM
It's okay in my apt on my wifi but disconnects from the network when I leave my apartment. I then have to power ot airplane mode it. My voicemail is finally working again but the text is hit or miss. Visible called me and they did a fignal of some sort. They were nice;
11-01-2024 08:44 PM
So the guy with 2.5 years owning a smart phone is going to get on here and say what they did shouldn't be a problem and then try to say it's their phones "antenna" ?? Really....? So I guess hundreds that I've seen, likely thousands of people messed up their phones antenna or have a tower down...? Go play tetris or whatever and don't comment on something you have no clue about, offer no contribution towards a solution and then blame their phones even though it's a MASSIVE chunk of customers with THE SAME EXACT PROBLEM.
11-01-2024
08:34 PM
- last edited on
12-17-2024
02:39 PM
by
kh_jenn
Yeah I have the same problem. Signal dropping out to no service many times a day. This I'd absolutely ridiculous and if you're using verizon towers and owned by Verizon then you need to act like it or you might as well shut this whole program down because at the end of this billing period I'll be switching services if this is still happening. And it likely will be. I even upgraded from basic to + to try to resolve the issue. Now I'm paying almost double for the same issues. NO OTHER PHONE SERVICE DOES THIS. NO OTHER PHONE SERVICE HAS THIS MANY PEOPLE WITH THE SAME PROBLEM FOR APPARENTLY TWO YEARS NOW FROM WHAT I SEE. And you have the nerve to associate this service with verizon in order to sell plans, knowing this is a MAJOR issue across probably 70% of your customer base. If not more. And then do ABSOLUTELY NOTHING AT ALL for years, to change anything or fix anything. Get it together because you're about to lose a + customer and I'm sure MANY MANY more on top of the ones already lost. And I so hope that someone at visible reads these things so if they do..
THANKS FOR NOTHING VISIBLE!
-Sincerely,
P*ssed off customer
Thursday
The S22 seems to have quite a few issues. Something I didn’t realize before accepting the free upgrade from the insurance company.
Based on what I’ve read, the problem isn’t limited to a single carrier. It appears to be a broader, systemic issue affecting devices across multiple networks. There’s also some debate about whether the root cause is software or hardware. I did read that some users didn't start having issues until after an update late 2023.
I’ll share a link below where a couple of users outline what they did to resolve the connectivity issues:
https://xdaforums.com/t/s22-ultra-network-connection-issues.4652675/post-89718284
And here’s the full thread for context:
Side note: Some S22 units seem to work just fine, so it really feels like a roll of the dice situation
Hope this helps someone.
