Samsung
Vanbrandt
Can a Samsung A-7-1 5-g uw be transfered to a new Visible account?
You would need to check your IMEI number to see if it is compatible. To find the IMEI number click settings button and scroll down to about phone and click on it. Click on the link below and select android and type the number in.
