โ10-11-2023 08:04 PM
I have an iPhone 11 Pro, running iOS version 17.0.3, and just switched from AT&T to Visible+. My number has also been ported and I verified I can make texts/calls/use data.
I can send iMessages to individual numbers, as before, but have lost the ability to send iMessages to groups. All members in the group have iPhones and the functionally was working right before my switch to Visible+. Messages are only sent as SMS to groups now.
So far I have tried troubleshooting by:
1. Relaunched the Messages app
2. Restarted the phone
3. Made sure Group Messaging and MMS Messaging were enabled
4. Deleted and restarted a group thread
5. Reset my network settings
This feature is important to be able to use the Messages app on different Apple devices. For example, SMS messages do not show up in the Messages app on a Macbook. Does anyone have an idea how to fix this issue?
โ10-11-2023 08:26 PM
My issue was solved by a post by @gothaggis. My iMessages Send & Receive setting had updated after switching. I had to go to "Settings -> Messages -> iMessage Send & Receive - my phone number was not selected. Selecting it fixed the problem."
โ10-11-2023 08:07 PM
โ04-24-2025 08:02 AM
I donโt see my phone number as an option. How do I add it?
โ04-24-2025 08:43 AM
Did you transfer your old number to Visible? If you have, I'd follow the troubleshooting steps Apple provides if you can't see your number - link.
