β10-30-2022 02:10 PM
I would like today to switch to visible from Verizon today but would like to keep our phone numbers.
β10-30-2022 08:13 PM - edited β10-30-2022 08:19 PM
From my understanding you should be able to when you port your number in from Verizon. If you have more than one number you are porting in I think you also need a separate account here for each number you are porting in which means you need a separate email for each account/number but you can use the same form of payment for each. There are no multiline plans here.
Try this link https://www.visible.com/help/Keep-your-number
β10-31-2022 04:37 AM
I ported out from Verizon to Visible
You will need a six digit port out pin and to make sure your Verizon number is not locked
https://www.verizon.com/support/port-out-faqs/
