โ02-17-2025 07:59 PM
I wish to switch phone service to visible. My old phone (Pixel 7) is broken. I have a new phone ( Samsung Galaxy S24FE) which I would like to transfer number to. How do I do that?
โ02-18-2025 06:48 AM - edited โ02-18-2025 06:50 AM
First go over to https://www.visible.com/help/how-do-i-transfer-port-my-number-to-visible and review the port-in requirements.
Once you have the port pin and info from your current carrier, go to: https://www.visible.com/shop/bring-your-own-device and Get Started where it begins with determining your phones compatibility.
Be sure to use someone's referral code for an addional $20 of your first month of service. Referral codes can be obtained from the Savings Spot or somebody's posting history under their profile.
โ09-06-2025 02:19 PM
I need selected phone numbers
