Traveling internationally - what to do?
jSquiddle
I'm new to Visible (on Visible+) and headed to Spain for a week. It looks like there's no coverage there, right?
So, I think the best approach is to get a local sim card, but the instructions on the Visible sight talk about swapping out the sim cards. Thing is, I use an eSim.
So, how to I get service in Spain if I'm using a Visible phone with eSim?
GreenSub
My iPhone SE can have 2 eSIMS active at the same time.
If you want to use your Visible number while in Spain, make sure WiFi calling, including cellular texts, works with Visible while in the US.
A free Google Voice account is always a good backup if thing go wrong overseas.
