08-19-2025 04:50 PM
I'll be traveling to Spain from the US beginning this weekend. This is my first trip overseas with Visible. Previously I had Verizon on my trips. I typically use an eSIM like Airalo, but inevitably Verizon would send me a text stating that Global Pass has been activated - as though my eSIM wasn't working, so the Verizon network would kick in and give me a charge for the day. This was especially annoying on my 3 week+ trips.
I'm curious how I can avoid the Global Pass activating on my upcoming trip with Visible. Do you keep "cellular" toggled off and make sure WiFi Calling is enabled?
Appreciate your help!
08-20-2025 04:33 AM - edited 08-20-2025 08:45 AM
With Visible you need to explicitly enable Global Pass and have autopay enabled. Login to your account and go to https://www.visible.com/account/global-pass to ensure global pass is disabled. SImply, disable autopay also to avoid any unexpected charges and reenable on returning if applicable.
