Turn OFF call waiting
lizey12
I am trying to turn OFF call waiting.
it is NOT an option on my phone.
I am told that it is a carrier-side option.
I am hard if hearing and the beeping causes me trouble when I am in the middle of a call.
Visible insists that it is on my side.  It is not.    Same with Verizon who had to cut it off on their side.
has anyone had any assistance from Visible getting call waiting turned off?      All I can get is them pointing at me but no one actual investigates the problem.
6 REPLIES 6
Hey there! If you're using an iPhone, call waiting can be disabled by going to Settings > Phone > Call Waiting. On an Android, you should be able to locate the feature in the Phone app or in your Call Settings.
While appreciate your answer, unfortunately, that doesn't work in my situation.   For whatever reason, the "Call Waiting" is NOT an option on my iPhone.     According to the advice from Apple, this IS a carrier-side issue.    I would really like some help with this.   Again, I do NOT have this setting on my phone.   https://discussions.apple.com/thread/8274683
I too have an iPhone and I have a Visible that gives me no options on my phone to shut off call waiting. I do not like waiting. I do not want call waiting and yet they can’t change it and blame me.
somefunname
Same problem here. I just got several calls while I was on a call with my iPhone. They should have gone straight to voice mail. When I checked the settings, Call Waiting was already turned off.
Did you ever find a solution?
Exact same problem, 8 months after the last post.  My call waiting appears to be turned off, but almost every call is interrupted by the beep.  Is there a solution to this yet?  Iphone 12
Tomandmary44
I too hate call waiting    Yes Verizon always had to turn mine off too.   Now I have Visuble and as you said I again cannot change it!!!  They point finger at me too like id lie about it?!
irritates me and I will have to change carriers once again.
