09-12-2022 02:39 PM
I received a sim from Visible in the mail when I switched my plan from Canadian to U.S. based. I am hoping to temporarily switch to Visible+ in order to contact relatives living internationally. Do I need to get another sim or can I simply switch plans online?
Thanks
09-12-2022 07:43 PM
I believe you can simply change the plan because it's the same network.
