โ01-22-2024 11:20 AM
I was wondering if I could use the Nokia 2780 flip phone with Visible's service. Is it possible to do this? If so, how? If not, are there any other flip phones I can use? Thanks.
โ01-22-2024 10:54 PM
Hi @BrettW55 - It appears that it might work according to reddit. However, it looks like you would need to activate the SIM card in another phone then move it over to the Nokia. This is not a Visible supported method but seems it should work.
