05-22-2025 08:54 AM
I’m not receiving any verification or activation codes since switching to Visible. Already toggled airplane mode and turn device off a couple times. Any idea how to fix this?
05-27-2025 02:32 PM
I had this same issue and just got it fixed with Sam at Visible. Text: START to 868722
I had a TON of texts pour in once I did that - all the verification codes I had not received over the past few weeks and also auto texts from my dog groomer saying my dogs were ready. So happy with their support!
07-30-2025 09:08 AM
Visible customer service helped me through chat. It took 3 separate chat sessions for them to reprovision my phone 3 times to finally get it to receive short code text messages! The way to confirm that you're getting text messages or verification codes from the vendor is to text them. You can google the unique short codes for specific vendor (for example Venmo - 86753). Send a text message such as START or HELP to the vendor. If you get an automated text reply, then you are connected and good to receive verification codes and texts from the vendor. If you don't get a reply from your text, then you're not connected. Work with a Visible chat agent. First, they had me do the usual stuff like reseating my physical sim card and switching airplane mode on/off. That didn't work. So insist that they reprovision your phone. It'll work.
