04-09-2022 11:34 AM
New Visible member today and WiFi calling is working fine over Comcast on my iPhone 11 with eSIM in metro Atlanta.
Will Wi-Fi calling and texting using my Visible number work overseas?
05-31-2022 08:09 AM
Following. I would like to know also.
08-03-2022 06:14 AM - edited 08-03-2022 06:14 AM
I think it should work fine, not find a reason not to work. The main selling point for WiFi calling is that you have cellphone reception in remote areas if you have internet connection.
I haven't tested myself with international travel after COVID-19 pandemic.
I used WiFi calling without any issues on Magenta network internationally in the past.
01-22-2023 07:06 AM
I just made a call to the USA from a country in Asia using WiFi calling on Visible. I had airplane mode on on my phone. It worked great.
01-22-2023 07:12 AM
I just made a WiFi call to the USA from a country in Asia using WiFi calling on Visible. It works great.
