Winegard - Visible Community
Winegard
Yoda
Can I use the sim card in a winegard connect 2?
Hey there!
At this time, cell signal boosters/network extenders/etc. are not compatible with Visible. here is the link to the list of our compatible devices https://www.visible.com/help/compatible/. You could also subscribe to our Visible newsletter located at the bottom of the www.visible.com website for future changes, so that you can stay tuned!
