โ10-21-2024 11:07 AM
hello, if my phone is lost, dies or is not working, then how can i get my voicemails from another phone or another method, such as email?
thanks, david
โ10-21-2024 03:02 PM
I don't think it is possible to call the number from another phone to access the voicemail like you can with a landline. Off the top of my head the only way would be to transfer the pSIM or eSIM to another device and access the normal way.
โ09-18-2025 06:24 AM
Dean, thanks for the reply.
currently, my pixel 6a uses a physical nano SIM card.
however, the phone supports eSIM.
is there a way to switch from physical SIM card to eSIM?
thanks, david
