activation for upgrade - Visible Community
Hello.  The app I try to download on my iPhone 7 does not download.  I am repeatedly told to try again later when trying to access the Visible app.  I cannot activate the new SIM without using this app...
What can I do to get around this?
I don't think you will find a work around. I don't think your phone can update to the operating system that is required for the app. The requirements for the Visible app is iOS 15.5 or later. You need the app to activate so I think you are stuck until you get a newer phone.
Try from laptop on visible.com?
