areas of Visible coverage
PithyKat
This may be a second request for the same issue (obviously new here); want to know how to find out if where I live is covered by your service as many have noted it to be a 'dead zone' before purchasing a phone and service plan.  Thank you!
rjniles
Most area should be covered the same as Verizon but there are a few areas that Verizon will have coverage because of their roaming agreements that Visible will not get. Visible does have domestic roaming but not at the same level as Verizon does. This is just from what I have been reading so not sure it is true or not.
You can try this map that Visible has.
https://www.visible.com/plans/coverage
