β06-23-2022 11:55 AM
Wanted to see if anyone had any suggestions on this situation? I have an AT&T Samsung Galaxy Fold 3 with my primary SIM on AT&T. I saw a release (shared with me on another sub) that Visible is now listing the Fold 3 as compatible for eSIM ( https://www.visible.com/newsroom/news/esim-for-android ) but when
I go to activate I'm getting a notice that it's not compatible and they only recommend swapping my device out! I reached out to a CS and they said some Fold 3 are not compatible yet......
I did run it thru Verizon's direct site for esim activation and had no issues (just don't want to pay $80 for the base plan)!
Any thoughts or recommendations?
β06-23-2022 02:06 PM
Is it an unlocked device? I don't know if an AT&T fold 3 is the same as a Verizon/Visible Fold 3? Maybe just chat with Visible and have them send you a real sim card...
Best!
β06-26-2022 07:49 AM
They can send me a sim, but I need to activate the esim to keep both lines
β06-26-2022 08:09 AM
Both lines? I didn't notice you mentioned anything about two lines in your original post. Good luck!
Best!
β06-26-2022 08:48 AM
I want to keep my primary line on AT&T and activate my esim on visible
