establishing second number on a single iphone
rcellison
I have a iphone XR with one account, I would like to add another phone number paired with another email address.
You should be able to since the XR says it has dual SIM capability. Just start another account.
Technically you could but as you know you need to create a separate account for that with visible.
Please note that most iPhones have single SIM card slot, however iPhones from iPhone X series supports eSIM. So you could have one number on physical SIM and another number on eSIM.
Please refer this article: https://support.apple.com/en-us/118669
