11-01-2022 11:11 PM - edited 11-01-2022 11:30 PM
I am currently using Pixel 3, and want to switch to Visible. I want to activate via esim and port my old phone number.
At beginning, it kept failing configure the esim, it may be related to permission problem of the app. I granted all permission to the app. I received an email said a new number was assigned to my account. However now I cannot login to my visible account. The error message just said "Something went wrong". I tried different browsers, doesn't help.
Where can I get help.
11-01-2022 11:45 PM
I am able to login now. But still cannot activate via esim. Working on it.
11-02-2022 05:47 AM
From what I have been reading here eSIM has been a huge problem on android phones and don't think they have been able to get it working properly. I would suggest you request a physical SIM card instead. I know there have been glitches with eSIM on iPhone but Visible has been getting some of the bugs out but I don't think they have been able to work the bugs out of android phones yet. I may be wrong though.
11-03-2022 12:31 PM
Hi, Pixel 3 is not supported for eSIM activation by Visible.
You'll need to use a SIM card or purchase a Pixel 4a or higher.
