goofy little icons
perk_dp
what are these goofy icons used by visible that seem to mean and do nothing ?
2 dots of a square
or 2 dots over a wavey line
similar to the one in the upper right of this community page
VisiblyPresent
Intermediate III
Stylized avatars, but goofy looking icons works just as well and they are meaningless. Go to your community settings & under avatars you'll find the complete set and that each actually has a name if you hover over them with . For example, yours is called "The Smile - Peach" while  mine is called "The 3 - Orchid".
