help understanding number switch
junior12785
Hello. I'm interested in the service. Exactly how does the number switch/bring your own number work? Does it automatically cancel what I currently have or do I have to call and cancel. Any information would help. Thank you
CJ
Intermediate
Hi, welcome to the Visible family.
Rule number 1: don't cancel your old service. Once the port goes through, your old service should terminate.
Visible has the rest of the steps here:
Visible | It's Phone Service. In An App.
A couple of other suggestions: use a referral code when you join Visible. That way your first month of service will be only $5. Here is one: Check out this page: https://www.visible.com/get/36mt7h , it has all the info you need to know about joining Visible. When you use my friend code, 36mt7h, youโ€™ll get your first month of service for only $5!
Two, join a party pay group. That way, instead of paying $40/month, starting with the second month you will pay $25/month. I would advise against joining a smaller party, just join one of the larger parties. Visible parties require at least four people to qualify for the $25/month rate. If you join a small group, you risk someone leaving during a month, and scrambling to find a replacement to maintain the $25/month rate.
Some other ways to save when joining Visible can be found here:
When you use my friend code, 36mt7h, youโ€™ll get yo... - Visible Community
If you need more info, please reply.
CJ
Intermediate
Thank you so much for your input.
