hotspot
pjb5
Hi,
Ive noticed my Visible hotspot wont open ebay or craigslist. It opens many other sites, but flags a certificate issue on these two. My Verizon hotspot had no issue with these sites. I tried different browsers. Suggestions?
I have had no problems with either site. Only thing I could suggest is try an incognito tab and see if that circumvents the issue or try clearing history along with cookies and see if that resets the browser. I am not to tech savvy but think it has to do with cookies so clearing them might work.
VisiblyPresent
Intermediate II
Certificate errors are caused by a number of reasons and display a number of unique error messages & codes   - provide the actual/precise error displayed.
beav
Any chance that you are on a VPN? Maybe consider suspending it.
