iPhone 12 Enable MMS message
MMCK1964
I just transferred from Verizon to Visible and now I cannot send a MMS message to android phones. I get the message to enable MMS, but it already is.  Any suggestions?
Thanks
MMCK1964
I tried everything on all the posts.  Then I tried the reset network...nothing. Then I tried reset phone and it worked.  MMS and groups texts work being sent to Android devices now.
Settings/General/Reset Phone/Reset - It took about 5 minutes.
MMCK1964
Reset what?
Florida
Thank YOU!  after 2 days with the same problem I read this post and reset ALL SETTINGS on my IPhone 12.  This does not remove data/photos/files.  Just SETTINGS.  This worked!!!!
