iPhone (7) - Visible Community
iPhone (7)
JJares
I was gifted with an iPhone (7) from my daughter. However, she used it @ Houston Methodist Hospital. When I turned the phone on, it said something about Remote Management (related to Houston Methodist). Can I use this phone? What do I do about the Remote Management? Do I need to remove it? How?
I can't be of much help other than to check if you can use the phone with Visible you can check it using this link. Select iOS and you will need the IMEI number for the phone.
As for the rest of your questions maybe someone else can help or maybe contact your daughter she may be able to help with that.
GreenSub
On the iPhone go to Settings - General - Transfer or Reset iPhone - Erase all Content and Settings
On a standard iPhone this would erase everything, Iโ€™m not sure if this will work on one with a corporate profile. Please let us know the results.
