not able to make calls or send texts on my activated account
lthullbery
my phone says activated from TMobile to Visible but unable to make calls or send texts
Unfamiliar with porting but if the port is finalized remove the T-Mobile SIM or delete the eSIM if that doesn't work you need to contact customer service.
