โ10-11-2022 06:22 AM
I am traveling to Mexico in November and want to be sure I can use my phone while I am there. Can someone tell me if it will work to call the US while I am in Mexico?
โ10-12-2022 04:51 AM - edited โ10-12-2022 04:52 AM
Only if you have (or upgrade to) the Visible+ plan ($45). The Visible plan ($30) only provides unlimited talk and text to Mexico, while the Visible+ plan also provides unlimited talk, text and roaming data in Mexico. See:
โ02-03-2023 05:34 PM
@Anonymous - I'm currently in Mexico and I'm using the Visible+ plan. I assumed it had some data along with it, but it seems like I'm unable to use any apps when not on Wifi, including WhatsApp. Is there any way to get data internationally through a Visible plan?
โ02-03-2023 05:36 PM
Hi @Anonymous, question - I'm currently in Mexico, and I'm using the Visible+ plan. Does it not include some data? I seem to be unable to use any of my apps off of wifi, including WhatsApp.
โ02-03-2023 05:39 PM
Really wish I could delete one of these duplicate posts... lol
โ12-28-2024 09:20 AM
Is any body use visible by Verizon in Mexico with the 45 plan and no charge for rooming?
