will my number eligible for port in benefit
shambhu81
Hi,
I am using a number provided by matrix cellular which has tie up with T mobile. Want to check if i will be eligible for number port in benefit as this provider is not listed in the list and would like to keep the same number.
If you're provider is not on the list you're not eligible for the gift card, but let me tell you a secret don't tell anyone,😀 visible has no way of knowing if the number was ported from tmobile directly, or from a tmobile dealer,... if you put in that you're number comes from tmobile than you're gonna get the promotion, I take no responsibility on this act I'm just telling you the fact
