08-27-2025 04:47 PM
I want to keep the existing number I already have with my phone. I have a Google Pixel and it is compatible with ESIM. Will getting a plan and ESIM allow me to use visible as a second phone number?? Can't seem to get any confirmation on this although I would think this to be the case
08-27-2025 06:04 PM
Yes, you can run two carriers or two numbers on a phone. You would need a new number for the Visible line which can be selected during the process. If you are already a Visible customer with one number you would need a separate account with a different email address. If you have an eSIM already you would have to check if your model allows for multiple eSIM's.
