Verizon Samsung Galaxy S21+5G
krose8114
Does anyone know how to make an unlocked Verizon Samsung Galaxy S21+5G compatible, if possible? Although the model is listed on Visible's website as compatible, it says it isn't when running the EMEI.
4 REPLIES 4
Hey there! Thanks for raising this concern. Our Care team will be best able to assist you here; please reach out by chatting on our site, tweeting @visiblecare or sending a DM to @Visible on Facebook.
Same problem here with s32, the 5G version.
Sorry, I meant the s21 (version 5G) phone.
highheater
Did you have any luck? You replied to my message with the same problem. MY IMEI is still listed as incompatible.
