Arlo Go
alisab
Since Visible uses Verizon 4-5G LTE, will I be able to connect my Arlo Go camera to my new Visible phone line?
This question has not been answered online to my knowledge. It's tricky because the Arlo Go uses a Verizon SIM card. I should be able to add my Arlo Go as an additional line (it has its own "phone number") but I can't seem to find the answer.
Thanks for any help!
Intermediate III
Try and let us know of your experience!
VisibleRocks
Superuser Founder
Superuser Founder
I don't believe Visible has added data plans for the Arlo Go, but you can chat with customer service to be sure.  Also, I'd suggest you post your suggestion at Visible | Feedback  I've been told that Visible monitors that forum to review how to expand services.  If this was helpful, please mark it as a solution.
