β01-20-2022 01:18 PM
β01-21-2022 05:48 AM - edited β01-21-2022 05:49 AM
You will need to activate your account first before you can use the party pay name you want to join.
-JustDoIt
β01-24-2022 08:27 AM
Hi Username7401,
Welcome to Visible.
When brand new to Visible, this can all seem a bit confusing.
JustDoIt's reply is correct. Additionally, I explain the process for not only joining a party, but also making the most of "refer a friend" codes, here. I hope this helps.
I wish you well.
