How to find out PIN associated with the account (not port-out PIN)
VS1
Hello,
I'm hoping someone could clarify this for me.
MetroPCS said it'd need both port-out PIN and account PIN.
I don't recall setting up account PIN when activating the service.  Visible (chat) agent said there is a PIN one can set for when using the app, but there is no such thing as account PIN.
I'm trying to confirm that account number and port-out PIN are sufficient for porting out.
Thanks in advance
D.
georgeb
Intermediate II
Yes certainly. From Visible you need the account number and the port out PIN.
georgeb
Intermediate II
Donovanwd
I’m having a similar problem. Visible is showing a wrong pin error for porting from my Metro account. I called Metro and changed my pin with same error. My son and I are on same Metro account with same pin and his port is going through. No one can or will help me at Metro and Visible.
