I want to switch from Verizon to Visible. If I sign up for Visible, will Verizon acct auto-cancel?
mabbott
I want to switch from Verizon to Visible. If I sign up for Visible, will Verizon acct auto-cancel? Do you have local stores where I can explore this. I don't want to download a switch, because something will go wrong.
illumiN8i
Yes, it will automatically cancel the Verizon account when the port is complete. I have heard horror stories on reddit about failed migrations from Verizon to Visible, but it worked perfectly for me migrating my number from Verizon Prepaid to Visible. The process took minutes. Visible does not have any local stores or phone support and I wouldn't count on chat support, so if you're not comfortable with self service, you might consider a different low cost carrier.
