Phone set-up
Kendall
I'm hesitant to go with Visible because there's no one to help me set up the phone with my apps.  Does anyone work with Samsung to do this.
4 REPLIES 4
Forty-Two
I wouldn’t hesitate. There’s a lot of help available on the forum here. Take it one by one to set up your apps. Post specific questions and you should get the help you need!
rjniles
If you are using a phone that is set up with your apps, changing the SIM card to Visible will not change your existing apps.
Forty-Two
@Kendall
I second what @rjniles posted. If you are not buying a new phone and only replacing the SIM, you shouldn’t have any changes needed for your apps. Usually recommend to backup your phone when making any change however, just to be extra careful.
VisibleRocks
Superuser Founder
Superuser Founder
@Kendall Please let us know if you decided to move forward.
