Silence unknown caller?
ejalford
I have a iPhone and it has setting to “silence unknown callers”. I’ve always used it with my other carrier. This is my first week with Visible and the setting is not working. Has anyone else had this same problem? Is there a fix?
jimjrfl
I'm using an XR running iOS 15.1   I know this my not be helpful but I do not have that issue. works on my phone. Did ya try all the usual stuff of making sure your using the latest iOS version? Rebooting the phone?
That's my 2 cents. Wish I had a better answer
Button
Ejalford,
Try resetting Network Settings.
~Button
