Can my Iphone using Visible?
Kleyn
My Iphone was purchased in China, And this is its detail. Is it can work with Visible?
Model Name iPhone 13
Model Number MLDY3CH/A
Serial Number JGDKVNLQ9P
VisibleRocks
Click here to check your IMEI compatibility  https://www.visible.com/help/compatible
You can do visible esim trial for 15 days. If it works for you then you can sign up.
