eSim not working on a ported number
JY
How can I get the eSim on my wife's phone resent without waiting on a chat for hours?
beav
1. Chat staffing varies during the day. If the chat que is long now, try again in a few hours.
2. I have had better luck with the Twitter DM support. They generally seem quicker to respond.
Good luck!
TJ1
In my case, Chat had me 1) delete Visible app 2) re-install Visible app 3) you will be prompted to have Visible send new eSim
